- 1 Level 2 Raspberry Pi
- 1.1 Setup
- 1.2 Piardu Configuration
- 1.4 Piardu Description
Setup
What you need
Fast setup for Advanced user
Here the full setup process:
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
Pi Software part
sudo apt-get update
sudo apt-get upgrade
Python3 Idle
Pygame
Paho Mqtt
KST Plot
DosToUnix
Arduino IDE
cd Downloads/arduino-1.8.13
sudo ./install.sh
PiArdu Software
Using VNC Viewer :
cd Documents
cd PiArdumower
cd Documents/PiArdumower
dos2unix Restart.py
cd ~/Desktop
dos2unix mower.sh
Automatic start on Power up:
DUE Connection
With DC/DC regulator
FLASH DUE
CHECK COMMUNICATION
change with:
Optional Screen
cd LCD-show/
sudo ./LCD5-show
Optional Camera
Check to Enable the Camera
Expérimental AI Vision with Tensorflow
Only OK with Raspberry 4 and Fan mandatory on the Pi.
PCB part:
GPS part:
Arduino Nano part.
NanoConnectedOnPi
Battery part:
AutoRecordBatCharging
Debug part:
UseDebugConsole
Sender part:
Camera part:
myCamAngle
streamVideoOnPower
Power ON
https://youtu.be/Qhv8r2bD_Bk
Power OFF
https://youtu.be/4YJQ-zyLq-Q
Piardu Description
It's here : [[1]]
