Version vom 7. November 2020, 15:03 Uhr von Bernard (Diskussion | Beiträge) (→‎Pi Software part)
Level 2 Raspberry Pi
What you need
Advanced user
Or simply follow the full WIKI
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
NOW WE WORK ON PC OR TABLET
Pi Software part
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install idle3
sudo pip3 install paho-mqtt
sudo apt-get install kst
cd Downloads/arduino-1.8.13
sudo ./install.sh
