Version vom 7. November 2020, 14:12 Uhr von Bernard (Diskussion | Beiträge) (→‎Pi Software part)
Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
NOW WE WORK ON PC OR TABLET
Pi Software part
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install idle3
sudo pip3 install paho-mqtt
sudo apt-get install kst
Do not forget to add the DUE board in board manager and use the native usb port
