Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
Pi Software part
NOW WE WORK ON THE PI USING VNC VIEWER ALL COMMAND NEED TO RESPECT THE CASE DO NOT DISCONNECT THE SCREEN TO HAVE A CORRECT RESOLUTION (10
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install idle3
sudo pip3 install paho-mqtt
sudo apt-get install kst
Do not forget to add the DUE board in board manager and use the native usb port
