Version vom 7. November 2020, 12:29 Uhr von Bernard (Diskussion | Beiträge) (→‎Pi Software part)
Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
NOW WE WORK ON PC OR TABLET
Pi Software part
You need to send some command to the PI Terminal to install so software.
Copy and past this command in the terminal after the $
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install idle3
