Version vom 5. November 2020, 20:32 Uhr von Bernard (Diskussion | Beiträge) (→‎PI Initial boot with Desktop)
Level 2 Raspberry Pi
What you need
Build the SD Card
USB Dongle for mouse.
On first start you can see welcome message and the IP Address for Ethernet
WIFI connecting
Validation and wait again 10 to 30 minutes
