Version vom 5. November 2020, 20:26 Uhr von Bernard (Diskussion | Beiträge) (→‎PI Initial boot with Desktop)
Level 2 Raspberry Pi
What you need
Build the SD Card
USB Dongle for mouse.
On first start you can see welcome message and the IP Address for Ethernet
Change password and remember it (we need it later to connect to PI over wifi) For easy wiki : Pass001
Setup screen
WIFI connecting
Validation and wait again 10 to 30 minutes
