AzuritBer Firmware (English)
Version vom 27. Oktober 2020, 20:13 Uhr von Bernard (Diskussion | Beiträge) (→‎What is AzuritBer and Why)
AzuritBer was build for DENNA,ROBOMOW and PARANELLO platform and use Odometry or IMU to control the state change. It can only run on DUE and Odometry is mandatory (minimum 400 ticks per rev).But it's possible to adjust setting to work for other kind of platform.
This version always use odometry into all movement (reverse,roll etc...) .The result is a more smooth movement without pause between all the diffrents state and the possibility to mow by lane and not only random.
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
are correctly set.
Odometry Setting
Motor Setting
