Bluetooth
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth module configuration steps
PC remote control application
We have developed a remote control application for PC (developed in Processing/Java):
Communication protocol
Example communication:
title [text1] [text2] [text3]
Sensor logging
