Hardware measurements
For detecting failures in the assembly or electronic parts, it is highly recommended to use an oscillscope (e.g. pocket oscillscope DSO201) for your measurements. Dso201.jpg
Error codes
 ERR_MOTOR_LEFT          Left gear motor error
                         * Check coil polarity
                         * Check left odometry cable
                         * Check left motor direction
                         * Check right odometry cable
                         * Check right motor direction
                         * Check battery connections
                         * Check charger connections
                         * Check GPS cables
                         * Check GPS antenna and cable
Console:
press...
d for menu
e=delete all errors
I2C errors
Ensure the I2C bus is working correctly. A console stucked at line 'initL3G4200D' indicates I2C is not working correctly.
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Robot not stopping to rotate when reaching perimeter (home mode)
Console output
 START
 Ardumower rXXXX
 press...
   d for menu
- After-home-drive? (1/0)
yaw - compass course
bat - battery voltage
chg - charger voltage sensor
--- commands ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
Sensor logging
  1. Diagnostic
