Motor driver
- Two motors (with integrated gearing) for driving (wheel motors) with integrated encoders (for distance and speed control)
Voltages
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- 24V (load current ~1A)
Motor wiring (left motor):
Motor decrease noise
Protector PCB
Protector board is adviced to be used between controller and motor
- Protector board (required for safe-use of motor drivers!)
- Building video: Dual MC33926
Odometry wiring
brown ---- PCB VCC green ---- PCB GND blue ---- PCB OdometryLeft (3) purple ---- PCB OdometryLeft (4)
odometry(3) --- 4.7k --- 5v odometry(4) --- 4.7k --- 5v
Mower motor wiring
Motor wiring (mower motor):
black ==== MC33926 M1OUT1 red ==== MC33926 M1OUT2
Motor controller (PID)
