Motor driver
- Two motors (with integrated gearing) for driving (wheel motors) with integrated encoders (for distance and speed control)
Voltages
As in all modern systems, the Ardumower uses 24V motors.
Wheel motors
- steer the robot left/right
- 24V (load current ~1A)
Motor driver (dual MC33926)
Features: up to 3A with integrated current sensor and thermal shut-down protection
Protector board is adviced to be used between controller and motor
Building video
Motor wiring (left motor):
black ==== MC33926 M1OUT1 red ==== MC33926 M1OUT2
brown ---- PCB VCC green ---- PCB GND blue ---- PCB OdometryLeft (3) purple ---- PCB OdometryLeft (4)
For right motor, use MC33926 M2OUT(1,2) and PCB OdometryRight accordingly.
odometry(3) --- 4.7k --- 5v odometry(4) --- 4.7k --- 5v
Mower motor
Motor wiring (mower motor):
Motor controller (PID)
