Motor driver
- Two motors (with integrated gearing) for driving (wheel motors) with integrated encoders (for distance and speed control)
Voltages
Although there exist 12V motors and 24V motors, as in all modern systems, the Ardumower uses 24V motors.
Wheel motors
- steer the robot left/right
- 24V (load current ~1A)
Motor driver (dual MC33926)
Features: up to 3A with integrated current sensor and thermal shut-down protection
Protector board is adviced to be used between controller and motor
Motor wiring (left motor):
black ==== MC33926 M1OUT1 red ==== MC33926 M1OUT2
Odometry wiring (left motor):
brown ---- PCB VCC green ---- PCB GND blue ---- PCB OdometryLeft (3) purple ---- PCB OdometryLeft (4)
For right motor, use MC33926 M2OUT(1,2) and PCB OdometryRight accordingly.
odometry(3) --- 4.7k --- 5v odometry(4) --- 4.7k --- 5v
Mower motor
Motor wiring (mower motor):
Motor controller (PID)
