Ardumower PCB
Needed modules
- Main functions
- Adjustable DC voltage step-down modules (3.3v, 5v, 8v)
- current sensor module
- Resistors, Capacitors, Fuse
- Perimeter sender (optional)
- Arduino Nano
- DC voltage step-down module
- pre-amplifier module
- Capacitor, Receiver coil
- Additional modules
- PCB dimensions 241x114mm
- Uses the Arduino Mega 2560
PCB versions
- Schematics
- Photos
- WorkaRound20150527
- WorkaRound20150530
- motor driver protection
PCB jumpers
D7: DIODE
D7: SHORT-CIRCUIT
JP6: OPEN
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
JP9: CLOSE |
JP8: CLOSE
JP9: OPEN |
PCB modules
PCB connectors
| P4 | reserved | Yes | ||
| P6 | Lawn sensor | Yes | ||
| P7 | Status LEDs | Yes | ||
| P22 | Reserved | Yes | ||
| P23 | Reserved | Yes | ||
| P24 | Reserved | Yes | ||
| P25 | Reserved | Yes | ||
| P26 | Reserved | Yes | ||
| P27 | Reserved | Yes | ||
| P28 | Reserved | Yes | ||
| P29 | Reserved | Yes | ||
| P32 | GND | Yes | ||
| P33 | 5V | Yes | ||
| P34 | 3.3V | Yes | ||
| P36 | Reserved | Yes | ||
| P37 | Mower motor | No | ||
| P38 | Reserved | Yes | ||
| P39 | Reserved | Yes | ||
| P45 | Reserved | Yes | ||
| P46 | Reserved | Yes |
You have two options:
First-time calibration
Wheel motors
ADC calibration
Diagnostics/troubleshooting
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
