Error codes
If your robot periodically beeps, it is in ERROR state. Either the serial console or pfodApp->Error Counters to find out the detailed error.
 ERR_MOTOR_LEFT          Left gear motor error - Check gear motor driver module and left gear motor
 ERR_MOTOR_RIGHT         Right gear motor error - Check gear motor driver module and right gear motor
 ERR_MOTOR_MOW           Mower motor error - Check mower motor driver module and mower motor
 ERR_MOW_SENSE           Mower motor over-current - Check mower motor driver module and mower motor
 ERR_IMU_COMM            IMU communication error - Check IMU module connections
 ERR_IMU_TILT            IMU tilt error - Check IMU module and robot orientation
 ERR_RTC_COMM            RTC communication error - Check RTC module connections, battery etc.
 ERR_RTC_DATA            RTC corrupt data error - Set ans save RTC date and time
 ERR_PERIMETER_TIMEOUT   Perimeter signal timeout - Check perimeter sender, wire etc.
 ERR_TRACKING            Perimeter tracking error - Check perimeter sender, wire etc.
 ERR_ODOMETRY_LEFT       Left motor odometry error - Check left odometry cable
 ERR_ODOMETRY_RIGHT      Right motor odometry error - Check right odometry cable
 ERR_BATTERY             Battery error - Check battery connections
 ERR_CHARGER             Charger error - Check charger connections
 ERR_GPS_COMM            GPS communication error - Check GPS cables
 ERR_GPS_DATA            GPS data error - Check GPS antenna and cable
 ERR_ADC_CALIB           ADC calibration error - Start ADC calibration (either via Console or pfodApp->ADC calibration)
 ERR_IMU_CALIB           IMU calibration error - Start IMU calibration (either via Console or pfodApp->Settings->IMU)
 ERR_EEPROM_DATA         EEPROM data error - Save user settings (either via Console or pfodApp->Settings-Save)
Disabled all pins not connected
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Console output
 START
 Ardumower rXXXX
 press...
   d for menu
- After-home-drive? (1/0)
yaw - compass course
bat - battery voltage
chg - charger voltage sensor
--- commands ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
  1. Diagnostic
