Charging
Basic principle
Charger
Battery
Idea:
- User presses existing START/POWER button, that switches on the relay for the time of pressing
- Arduino starts and immediately also switches on relay
- If undervoltage detected, Arduino switches off relay.
- Emergy button is still used for completely switching ON/OFF power.
- Emergency push button: can power-off the robot immediately
- POWER/START button: switches-on operation voltage (1st one second press), starts robot in automatic mode (2nd one second press)
- Arduino digital out pin (pinBatteryEnable): set to HIGH at bootup - set to LOW if undervoltage detected
- Arduino digital in pin (pinButton): Starts robot mower in automatic mode etc.
BOM: 1x IRF9540N P-MOSFET T1 (or IRF5210) 1x BC337 NPN T2 1x Zener Diode 15V ZD15 Z1 2x Diode 1N4148 D2, D3 2x Diode 1N5819 50V D1, D4 1x 22 uF C1 1x 1k R4 2x 10k (R3, R8) 1x 30k R6 2x 100k (R2, R7)
Robot charging
robot charging circuit:
---- voltage sensing
Charging station
charging station circuit:
Charging station ideas
