Motor driver
Version vom 22. Mai 2015, 11:15 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Mower motor and driver)
Ardumower's design uses two different types of motors (all motors can be purchased via the shop Shopping.png):
  • Two motors (with integrated gearing) for driving (wheel motors)
Voltages
  • The motor driver must be suitable for higher current (more expensive)
  • The PCB traces need to be more thick (more expensive)
  • The rechargable battery need to support higher current (more expensive)
Wheel motors
  • steer the robot left/right
  • Integrated encoders, so it can measure the rotation speed (see Odometry for more information) - Encoders are REQUIRED for Ardumower software.
  • 24V (no load current: 500 mA)
Motor driver
 Arduino Digital Pin  —>  MOTOR-Direction Pin (DIR)
 Arduino PWM Pin      —>  MOTOR-Speed Pin (PWM)
 Arduino Analog Pin   <—  MOTOR-Current Sensor Pin
PWM frequency
Popular modules
MC33926 (recommended)
M1_FB     --- pinMotorLeftSense A1
M1_SF     --- pinMotorLeftFault 25
M1_IN1    --- pinMotorLeftPWM 5
M1_IN2    --- pinMotorLeftDir 31
M2_FB     --- pinMotorRightSense A0
M2_SF     --- pinMotorRightFault 27
M2_IN1    --- pinMotorRightPWM  3
M2_IN2    --- pinMotorRightDir 33
VDD       --- Arduino 5V
L298N
Connect in parallel:
IN1 with IN4
IN2 with IN3
OUT1 with OUT4
OUT2 with OUT3
L9958
L9958 GND---GND
L9958 VCC---Arduino 5V
L9958 EN---Arduino 5V
L9958 DI---GND
L9958 DIR---Arduino MOTOR_DIR
L9958 PWM---Arduino MOTOR_PWM
L9958 MOTOR(+)---motor(+)
L9958 MOTOR(-)---motor(-)
L9958 POWER(+)---battery(+)
L9958 POWER(-)---battery(-)
Choosing a driver
  • price
Starting current
Starting current:
  • Gear motor: 15A (starting current peak)
  • Mowing motor: 20A (starting current peak)
Short-circuit current
Warning
  • always remove blades
Example measurement:
  • Rotenbach SPM08-320
    • Wheel motor: 8A
    • Mowing motor:
  • Ambrogio L50
    • Wheel motor: 4,5A
    • Mowing motor: 22A
  • Tianchen TC-G158
    • Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
