Motor driver
Voltages
Wheel motors
- steer the robot left/right
- A rotation speed up to 31 rpm allows to move the robot at sufficient speed (at up to meter/sec = 33rpm/60 * PI * 0.25m = 0.4m/sec using 250mm diameter wheels)
- Integrated encoders, so it can measure the rotation speed (see Odometry for more information)
- 24V
Motor driver
PWM frequency
Popular modules
MC33926 (recommended)
L298N
Connect in parallel:
L9958
Mower motor and driver
- 24V, rated current 2.7A (L=2.8mH, R=1.9ohm)
Choosing a driver
- price
Starting current
Starting current:
Short-circuit current
Warning
- always remove blades
Example measurement:
- Rotenbach SPM08-320
- Wheel motor: 8A
- Mowing motor:
- Ambrogio L50
- Wheel motor: 4,5A
- Mowing motor: 22A
- Tianchen TC-G158
- Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
