Charging
Version vom 19. April 2015, 23:28 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Charging station ideas)
Basic principle
Charger
Battery
For the battery, we are using a 'Sony Konion 7S2P' Lithium Ion battery pack (Sony Konion US18650V3 2250 mAh cells, Li-Mn), 29.4V, 4500 mAh, 500 recharge cycles, 126 x 36 x 65 mm (LBH).
Idea:
User presses existing START/POWER button, that switches on the relay for the time of pressing - Arduino starts and immediately also switches on relay - if undervoltage detected, Arduino switches off relay. Emergy button is still used for completely switching ON/OFF power.
  • Emergency push button: can power-off the robot immediately
  • POWER/START button: switches-on operation voltage (1st one second press), starts robot in automatic mode (2nd one second press)
  • Arduino digital out pin (pinBatteryEnable): set to HIGH at bootup - set to LOW if undervoltage detected
  • Arduino digital in pin (pinButton): Starts robot mower in automatic mode etc.
BOM:
1x IRF9540N  N-MOSFET   T1
1x BC337 NPN   T2
1x Zener Diode 15V ZD15  Z1
4x Diode 50V D1, D2, D3, D4
1x 22 uF C1
1x 100k  R2
1x 1k R4
1x 10k R3
1x 100 R7
1x 30k R6
1x 10k R8
Robot charging
robot charging circuit:
                             ---- voltage sensing
Charging station
charging station circuit:
                    GND         (-)----- Charging station charger pin(-)
  2. Drive in and out
  3. Tracking and docking
