Motor driver
Ardumower's design uses two different types of motors (all motors can be purchased via shop
Voltages
There exist 12V motors and 24V motors. As in all modern systems, the Ardumower uses 24V motors. The reason is as follows:
Wheel motors
- steer the robot left/right
- A rotation speed up to 33 rpm allows to move the robot at sufficient speed
- A high torque (3Nm) guarantees that the robot can climb small hills as well
- Integrated encoders, so it can measure the rotation speed. This allows Ardumower to correct the driving angle (see Odometry for more information)
- 24V
Motor driver
Popular modules
MC33926 (recommended)
For the 0.9.3 Version
M1_FB --- Motor1 current sensor output (Arduino) M1_PWM_D1 --- connect with jumper to GND M1_PWM_D2 --- connect with jumper to VDD M1_IN1 --- Motor1 PWM (Arduino) M1_IN2 --- Motor1 Dir (Arduino) EN --- connect with jumper to VDD M2_FB --- Motor2 current sensor output (Arduino) M2_PWM_D1 --- connect with jumper to GND M2_PWM_D2 --- connect with jumper to VDD M2_IN1 --- Motor2 PWM (Arduino) M2_IN2 --- Motor2 Dir (Arduino) EN --- connect with jumper to VDD VDD --- Arduino 5V
For the SVN Version
L298N
Connect in parallel:
L9958
Features: Arduino 240W H-bridge Motor Driver Board - SX8847, up to 8A (for Rotenbach SPM08-320 etc.).
Mower motor and driver
- Enough torque (140 mNm)
- 24V
Choosing a driver
- price
Short-circuit current
Warning
- always remove blades
Example measurement:
- Rotenbach SPM08-320
- Wheel motor: 8A
- Mowing motor:
- Ambrogio L50
- Wheel motor: 4,5A
- Mowing motor: 22A
- Tianchen TC-G158
- Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
