AzuritBer Firmware (English)
- 1 GITHUB Location
- 2 Test requirements
- 3 What is AzuritBer and Why
- 4 Possible Option
- 5 Level 1 Standard
- 5.1 Install Firmware in DUE
- 5.2 Arduremote
- 5.3 Main
- 5.4 Command
- 5.5 Console
- 5.6 Setting
- 6 Level 2 Raspberry Pi
GITHUB Location
It's here:
WIFI ESP32 Sender
The new sender is describe here:
Level 1 Standard
Level 2 MQTT
It's the standard PCB1.3 but the BT module is ESP32 one
Level 3 RFID/MQTT
It's the standard PCB1.3 but the BT module is ESP32 one and a PN5180 RFID reader is connected to the ESP32
Level 4 Raspberry
It's Level 1 but now:
Level 5 Raspberry + Rfid reader
Level 1 Standard
Arduremote
Main
Command
Arduremote
Possible value are :
Button connected on P20
If mower is in OFF state:
If mower is running:
Push it to stop immediately
Console
Setting
Here the setting page.
Set Force mowing off to YES
ODOMETRY Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
CONSOLE SHOW:
Value 2
Value 3
MOTOR Setting
See PID Control : [1]
MOW setting
Set the PWM Max speed to 255
Set the PWM Min speed to 150
STATION setting
PERIMETER setting
Mini Smag:
Timeout(s) if outside :
Big AREA Smag Center
Tracking Max Speed PWM
Circle Arc Distance...
Perimeter MAG MAX VALUE
Transition Timeout
Track Error Timeout
Track PID
Coil Polarity
Read the 2 coils
Block inner wheel
Reduce Speed Near Wire
Actual Speed Coeff
IMU Wiring and Setting
MPU-9250 IMU WIRING TO PCB1.3
GY-88 IMU WIRING TO PCB1.3
GY-87 WIRING TO PCB1.3
IMU Main Setting
IMU Use
Stop Mow Motor During Calib
P I D
Calibration Max Duration
Delay between 2 calib
'Drift Maxi in Deg per Second
Speed to find ComYaw
SETTING Without Compass
To check if it's OK:
Go To : Main Menu / Test IMU
SETTING With Compass
CONSOLE SHOW :
TIMER setting
BYLANE setting
BATTERY setting
Charge Factor
Battery Factor
Sense Factor
Go Home if Volt below
Switch off after minutes
Switch off if Volt below
Start charge if Voltage below
Stop charge if Sense below
SONAR setting
Sonar brake below
Sonar To Front Dist
RAIN TEMP setting
Rain Use
DHT22Use
Maximum Temperature
OLED Screen setting
In OFF mode :
While mower running :
When Charging :
