Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
Connect everything on the PI.
USB Dongle for mouse. HDMI cable from PI to TV or monitor. Ethernet cable if possible or WIFI (On first boot the PI need a good connection to the net for last update)
On first start you can see the IP Adress
Select your langage and location.
Change password and remember it (we need it later to connect to PI over wifi) For easy wiki : Pass001
Setup screen
WIFI connecting
Validation and wait again 10 to 30 minutes
