Bluetooth
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth module configuration steps
In addition to the Android App, we have developed a remote control application for PC (developed in Processing/Java), the Mac version has to be created within Processing:
Communication protocol
Example communication:
title [text1] [text2] [text3]
Sensor logging
