Bluetooth
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth module configuration steps
PC remote control application
We have developed a remote control application for PC (developed in Processing/Java):
- Download and install Java runtime (versio 8 or higher): https://java.com/de/download/
Communication protocol
Example communication:
title [text1] [text2] [text3]
Sensor logging
