Charging
Version vom 6. Juni 2016, 13:51 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Standby-off / Under-voltage protection)
Here you can see the charging without charging station. If you don't want to use a charging station, the charger can be connected directly to the Ardumower. Ardumower battery overview.jpg
Charger
Total power balance
Battery
schematics
Robot charging
Charging station
Here you can see the charging via charging station. Ardumower charging overview.jpg
  2. Drive in and out
  3. Tracking and docking
  4. Final version
