Laden
Here you can see the charging via charging station. If you don't want to use a charging station, the charger can be connected directly to the Ardumower.
Grundprinzip
Ladegerät
Leistungsbilanz
Akku
Laden des Roboters
Ladestation
Here you can see the charging stations contacts:
