Perimeter wire
Principle:
Signal
- increase the signal length
Filter
Sender perimeter lawn size
area = PI * (r*r) = PI * (18m * 18m) = 1000 m2
Sender current control
- Power resistor: If your perimeter wire resistance (R) is below 5 Ohms, you will not be able to further reduce voltage below 6.5v (otherwise the Arduino will not work properly). Then you have to increase the perimeter wire resistance (R) by using a power resistor (example: 5 ohm, 10W) in series with your perimeter wire.
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Sender automatic standby
Sender software
Sender diagnostics
Receiver
pfodApp->Options->Perimeter->"Timed-out if below smag" (timedOutIfBelowSmag) - default setting: 300 | If smag below this value, sender is considered as off (perimeter timeout appears)
pfodApp->Options->Perimeter->"Timeout (s) if not inside" (timeOutSecIfNotInside) - default setting: 8
pfodApp->Options->Perimeter->"Trigger timeout" (perimeterTriggerTimeout) - default setting: 0 | Perimeter outside trigger timeout when escaping from inside (ms)
pfodApp->Options->Perimeter->"Perimeter out roll time max" (perimeterOutRollTimeMax) - default setting: 2000 | Max (random generator) roll time after perimeter out (ms)
pfodApp->Options->Perimeter->"Perimeter out roll time min" (perimeterOutRollTimeMin) - default setting: 750 | Min (random generator) roll time after perimeter out (ms)
pfodApp->Options->Perimeter->"Perimeter out reverse time" (perimeterOutRevTime) - default setting: 2200 | Time to drive reverse after perimeter out (ms)
pfodApp->Options->Perimeter->"Perimeter tracking roll time" (perimeterTrackRollTime) - default setting: 1500 | Hit obstacle while tracking: roll time
pfodApp->Options->Perimeter->"Perimeter tracking reverse time" (perimeterTrackRevTime) - default setting: 2200 | Hit obstacle while tracking: reverse time
pfodApp->Options->Perimeter->"Transition timeout" (trackingPerimeterTransitionTimeOut) - default setting: 2000 | Max. time required for a in/out transition during tracking, robot will start rotating after this timeout
pfodApp->Options->Perimeter->"Track error timeout" (trackingErrorTimeOut) - default setting: 10000 | Max. time required for a in/out transition during tracking, robot will go into error after this time
pfodApp->Options->Perimeter->"Track_P" (perimeterPID.Kp) - default setting:51 | Perimeter PID "P" setting
pfodApp->Options->Perimeter->"Track_I" (perimeterPID.Ki) - default setting:12.5 | Perimeter PID "I" setting
pfodApp->Options->Perimeter->"Track_D" (perimeterPID.Kd) - default setting:0.8 | Perimeter PID "D" setting
pfodApp->Options->Perimeter->"Use differential signal" (useDifferentialPerimeterSignal) - default setting: YES | Use differential signal (see signal section)
pfodApp->Options->Perimeter->"Swap coil polarity" (swapCoilPolarity) - default setting:NO
pfodApp->Options->Perimeter->"Block inner wheel" (trackingBlockInnerWheelWhilePerimeterStruggling) - default setting: YES | robot is wheel-spinning while tracking => roll to get ground again
Signal measurements
Coil and noise measurements
Receiver ADC calibration
- Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m)
Broken perimeter wire
Measurements
Noise (max): smag=192 Signal (min): smag=254 SNR=Signal/Noise=254/192=1.3
Noise (max): smag=192 Signal (min): smag=896 SNR=Signal/Noise=896/192=4.6
- Perimeter2 demo
- 120m perimeter wire test
- Sender PCB
- Perimeter stop test
- Perimeter tracking test
