Perimeter wire
Principle:
Signal
- increase the signal length
Filter
Sender perimeter lawn size
area = PI * (r*r) = PI * (18m * 18m) = 1000 m2
Sender current control
- Power resistor: If your perimeter wire resistance (R) is below 5 Ohms, you will not be able to further reduce voltage below 6.5v (otherwise the Arduino will not work properly). Then you have to increase the perimeter wire resistance (R) by using a power resistor (example: 5 ohm, 10W) in series with your perimeter wire.
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Sender automatic standby
Sender software
Sender diagnostics
Receiver
perimeterTriggerTimeout: perimeter outside trigger timeout when escaping from inside (ms) perimeterOutRollTimeMax: max (random generator) roll time after perimeter out (ms) perimeterOutRollTimeMin: min (random generator) roll time after perimeter out (ms) perimeterOutRevTime: time to drive reverse after perimeter out (ms) perimeterTrackRollTime: hit obstacle while tracking: roll time perimeterTrackRevTime: hit obstacle while tracking: reverse time trackingPerimeterTransitionTimeOut : max. time required for a in/out transition during tracking, robot will start rotating after this timeout trackingErrorTimeOut: max. time required for a in/out transition during tracking, robot will go into error after this time trackingBlockInnerWheelWhilePerimeterStruggling: blocking of inner wheel related to direction of curve to steer (yes/no) pfodApp->Options->Perimeter->Timed-out if below smag: below this smag, sender is considered as off (perimeter timeout appears)
Signal measurements
Coil and noise measurements
Receiver ADC calibration
- Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m)
Broken perimeter wire
Measurements
Noise (max): smag=192 Signal (min): smag=254 SNR=Signal/Noise=254/192=1.3
Noise (max): smag=192 Signal (min): smag=896 SNR=Signal/Noise=896/192=4.6
- Perimeter2 demo
- 120m perimeter wire test
- Sender PCB
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
