Bluetooth
The application menu includes:
- Settings (Timer etc.)
Bluetooth module
On the robot, you'll need a Bluetooth module supporting Bluetooth Serial Port Profile (SPP). SPP uses Bluetooth Service Discovery Protocol (SDP) and the RFCOMM protocol. Depending on the desired range, you can use different Bluetooth classes:
- Bluetooth class 2 (up to approx. 50m range), e.g. HC03/04/05/06
- Bluetooth class 1 (up to approx. 100m range), e.g. BTM220, requires additional circuit
Bluetooth HC-05
For programming the Module, you must connect the Key Pin from the BT Module, to the 3,3 V from the Arduino (using jumper JP2) and disconect after. on the arduino console : press 'd' to enter menu and use option 3 to 'set up BT module config'.
Steps
- for HC05: Connect KEY pin to 3.3V after powering on the module (use jumper JP2)
- Baud rate: Bluetooth module and Arduino Mega must use the same baud rate (19200) - The baud rate of the BT module can be changed via Ardumower serial console. Connect Ardumower Mega board to your PC (USB), enter the serial console in the Arduino IDE (CTRL+M), and choose baud rate 19200, then choose 'd' to enter the Ardumower menu to configure the module (option 3 configure the BT module).
- Pairing: The BT module must be 'paired' with your Android device once (via Android device settings). On the Android device, choose symbol "Settings" (via Android menu). Now choose "Wireless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired".
Nota : If you experience difficulties to configure baud rate (step2), you can alternatively press the little switch on your BT module while powering up this will automatically set baud rate to 38400. then you can use option 3 of Ardumower menu to configure BT module (set name, pin code etc...). Detail information on configuring the BT module available here [1]
Nota : When you enter in menu mode (ardumower console press 'd'), you may experience timeout from bluetooth app. you need to exit from the menu for the robot to interact with your app (phone or tablet)
Communication protocol
Example communication:
title [text1] [text2] [text3]
