Motor driver ru
Описание
- Two motors (with integrated gearing) for driving (wheel motors), and encoder (for distance, direction and speed control)
Voltages
Wheel motors
- steer the robot left/right
- Integrated encoders, so it can measure the rotation speed, the distance and the direction (see Odometry for more information) - Encoders are REQUIRED for Ardumower software.
- 24V (load current ~1A)
Motor driver
PWM frequency
Popular modules
MC33926 (recommended)
Особенности: up to 3A with integrated current sensor and thermal shut-down protection, for all kind of robot mowers)
IBT-2 (BTS7960/BTN7960)
Особенности: 5.5-27V, 43A (цена 9 USD)
На один двигатель требуется один модуль.
1 RPWM Forward level or PWM signal input, active HIGH 2 LPWM Reverse level or PWM signal input, active HIGH 3 R_EN Forward drive enable input, HIGH enable, LOW Close 4 L_EN Reverse drive enable input, HIGH enable, LOW Close 5 R_IS Forward drive - side current alarm output 6 L_IS Reverse drive - side current alarm output 7 VCC 5V power input from Arduino board. 8 GND Ground.
BTS7960B GND --- GND BTS7960B VCC --- Arduino 5V BTS7960B R_IS --- нет BTS7960B L_IS --- нет BTS7960B R_EN --- Arduino MOTOR_DIR pinMotorRightDir 33 BTS7960B L_EN --- Arduino MOTOR_DIR pinMotorLeftDir 31 BTS7960B R_PWM --- Arduino MOTOR_PWM pinMotorRightPWM 3 BTS7960B L_PWM --- Arduino MOTOR_PWM pinMotorLeftPWM 5 BTS7960B MOTOR(+) --- motor(+) BTS7960B MOTOR(-) --- motor(-) BTS7960B POWER(+) --- battery(+) BTS7960B POWER(-) --- battery(-)
L6201P
Особенности: 48V, 4A
B+ power supply output voltage equal to the power connector GND GND EN driver enable RPWM forward PWM signal, active HIGH LPWM reverse PWM signal, active HIGH CT current signal output VT voltage signal output
Forward EN=1, RPWM=PWM, LPWM=0 Reverse EN=1, RPWM=0, LPWM=PWM (also possible? EN=1, RPWM=255-PWM, LPWM=1 => needs to be verified!) Brake EN=1, RPWM=0, LPWM=0 Not brake EN=0, RPWM=x, LPWM=x Note: 1=High level (3.3-5v), 0=Low level (0V or GND)
L9958
Особенности: Arduino 240W H-bridge Motor Driver Board - SX8847, up to 8A
L298N
Особенности: up to 4A Notice: When using a L298N-motor driver, both H-bridges (2A) should be connected in parallel, so that both bridges drive a single motor (max. 4A):
Connect in parallel:
Mower motor and driver
Choosing a driver
- price
Starting current
Starting current:
Short-circuit current
Warning
- always remove blades
Example measurement:
- Rotenbach SPM08-320
- Wheel motor: 8A
- Mowing motor:
- Ambrogio L50
- Wheel motor: 4,5A
- Mowing motor: 22A
- Tianchen TC-G158
- Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
