Realtime clock
Version vom 17. August 2015, 10:14 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Troubleshooting "Tiny RTC I2C module")
Realtime clock (RTC)
The robot requires a clock, so that it can start mowing automatically at certain time intervals (timer).
A realtime clock (RTC) returns current time (minute, hour) and date (day of week, day, month, year) - by the help of a battery the time continues to run even if the robot mower is switched off.
Additionally, the RTC module contains an EEPROM memory (non volatile memory) that can hold 4K of permanent user data.
Example: DS1307
If your module is losing time/date, fix the circuit like this:
  • Remove D1, R6 and R4
  • Solder jumper wire in place of R6
  • Inspect crystal soldering - fix if necessary
  • Replace battery
Wiring
The RTC module is connected on the I2C bus of the Arduino Mega (in parallel with any other I2C modules).
 DS1307 Module SDA       — Arduino SDA Pin
 DS1307 Module SCL       — Arduino SCL Pin
 DS1307 Module VCC (+5V) — Arduino VCC (+5V)
 DS1307 Module GND       — Arduino GND
Note
If you experience communication problems when using multiple I2C modules on one I2C bus, it is recommended to reduce the length of the cables.
Timer
Timer 3: off
Timer 4: off
