GPS
Version vom 22. Mai 2015, 20:58 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Visualization of GPS data)
Currently, GPS is used
GPS TX (3.3V compatible) -- Arduino RX
GPS RX (3.3V compatible) -- Arduino TX
GPS VCC -- Arduino VCC 5V
GPS GND -- Arduino GND
hdop    measurement error (the more satellites are from different directions, the less the error)
spd     ground speed
course  ground course
alt     altitude
lat     latitude
lon     longitude
GPS error
Typical GPS error is 2-5 meters (at a sample rate of 1 Hz). As this is not sufficient as a replacement for a perimeter wire, GPS can only be seen as an extension or for global navigation (navigation from one lawn to another lawn) or to improve the result of a sensor fusion.
