  1. Motors working correct?
  1. Any unexpected sensor triggering?
Run the serial console (Arduino IDE: CTRL+SHIFT+M, 19200 Baud), and start the robot. Each time a sensor triggers, the counter of that sensor will increase. See description of each sensor are below.
Now when your robot does something unexpected, have a look if any sensor counter increased to locate the problem.
  1. Some sensor not triggering?
  1. Bluetooth not connecting?
Console output
 START
 Ardumower rXXXX
 press...
   d for menu
In the Serial Console you got many Information about your Robot. Here ist what it means :
--- Messages from the serial ---
- After-home-drive? (1/0)
sen - current timeout counter engine: left, right, Mower
bum - Bumpercounter: left, right
pit / roll - inclination (calculated with Accel sensor)
com - Compass Course
by - inductive loop detector: counter
bat - Battery voltage
chg - charging current
--- Menu Konsole ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
  1. Diagnostic
