Perimeter wire
Version vom 12. September 2014, 13:07 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Tracking of perimeter)
Perimeter v1 (v0.9.3)
So, here's the sender:
It is recommended to use a voltage step-down converter (e.g. module using LM2596) to generate the 5V voltage. Before connecting, set the voltage of the converter to 5V. Warning : never connect more than 5V on the Arduino 5V pins, or you will damage the Arduino. Therefore, always measure the 5V voltage before connecting it to the Arduino 5V pin!
Functional test
Receiver
Principle:
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
Perimeter v2 (SVN version)
Receiver
