Motor driver
Voltages
Wheel motors
- steer the robot left/right
- A rotation speed up to 33 rpm allows to move the robot at sufficient speed
- A high torque (3Nm) guarantees that the robot can climb small hills as well
- Integrated encoders, so it can measure the rotation speed. This allows Ardumower to correct the driving angle (see Odometry for more information)
- 24V
Motor driver
Popular modules
MC33926 (recommended)
For the 0.9.3 Version
M1_FB --- Motor1 current sensor output (Arduino) M1_PWM_D1 --- connect with jumper to GND M1_PWM_D2 --- connect with jumper to VDD M1_IN1 --- Motor1 PWM (Arduino) M1_IN2 --- Motor1 Dir (Arduino) EN --- connect with jumper to VDD M2_FB --- Motor2 current sensor output (Arduino) M2_PWM_D1 --- connect with jumper to GND M2_PWM_D2 --- connect with jumper to VDD M2_IN1 --- Motor2 PWM (Arduino) M2_IN2 --- Motor2 Dir (Arduino) EN --- connect with jumper to VDD VDD --- Arduino 5V
For the SVN Version
L298N
Connect in parallel:
L9958
Features: Arduino 240W H-bridge Motor Driver Board - SX8847, up to 8A (for Rotenbach SPM08-320 etc.).
Mower motor and driver
- Enough torque (140 mNm)
- 24V
Choosing a driver
- price
Short-circuit current
Warning
- always remove blades
Example measurement:
- Rotenbach SPM08-320
- Wheel motor: 8A
- Mowing motor:
- Ambrogio L50
- Wheel motor: 4,5A
- Mowing motor: 22A
- Tianchen TC-G158
- Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
