Ardumower Sunray
Version vom 29. Mai 2022, 12:53 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Rover configuration (messages))
  2. Remove jumper Gps_S (JP12)
PCB 1.3 PCB 1.4
F0-00 F0-00 NMEA GxGGA    60
idle Robot is stopped.
dock Robot is docking.
charge Robot is charging.
Additionally, there is a motor plot for odometry signal quality diagnostics.
  1. Make sure the robots tires can move freely in the air
  3. Choose Tools->Serial Monitor from the menu, and send 'AT+Q' (ENTER) to the robot (115200 baud). The motor plot will start and motor PWM and odometry signal quality will be plotted:
PCB PCB PCB
volt=24
...some time later...
...many time later...
Automatic robot switch off
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
  3. Start XCTU
  2. NOTE: If you experience resets of your Xbee with the latest XCTU software, you have to use XCTU software version 6.5.6. You can find older XBee XCTU software here: https://www.digi.com/support/includes/utilities.aspx?pid=3352
Channel Mask: 3EFFFDFF
Network ID: 1985
Broadcast Multi-Transmits: 3
RD Data Rate: 80 kps
TX Power Level: 32 mW
Unicast Retries: A
Broadcast Hops: 0
Network Hops: 7
Mesh Unicast Retries: 1
Destination Address High: 0
Destination Address Low: FFFF
Transmit Options: 40
Node Identifier:
Network Discovery Options: 0
Cluster ID: 11
Encryption: Disabled [0]
AES Encryption Key:
Baud Rate: 115200
Parity: No Parity [0]
Stop Bits: One stop bit [0]
Packetization Timeout: 3
Flow Control Threshold: 11D
DIO0: Commissioning Button
DIO1: Disabled
DIO2: Disabled
DIO3: Disabled
DIO4: Disabled
DIO5: Assoc. Indicator
DIO6: Disabled
DIO7: CTS flow control
DIO8: Sleep Request
DIO9: ON/SLEEP Output
DI10: RSSI PWM0 Output
DI11: Disabled
DI12: Disabled
DOUT: UART_DOUT
DIN:  UART_DIN
DI15: SPI_MISO
DI16: SPI_MOSI
DI17: SPI_SSEL
DI18: SPI_SCLK
DI19: SPI_ATTN
Pull Direction: FFFFF
Pull-Up: FFFFF
PWM0: 0
PWM1: 0
Associate LED Blink Time: 0
RSSI PWM Timer: 28
Sleep Mode: Normal
Sleep Options: 2
Sleep Time: 190
Wake Time: 1F40
Wake Host Delay: 0
