Ardumower Chassis 'mountain mod'
Version vom 13. September 2021, 18:00 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Turning front drive into rear drive)
  2. optional: modifying the tire profile (give it more grip)
    1. Modify tire profile OR
Needed parts
  • cup
  • acrylic glas sheet (1mm)
  • rubber band (U-form)
  1. swap motor cables (right and left)
  2. swap odometry cables (right and left)
  3. swap battery charging pin cables (right and left)
  4. disable ultrasonic sensor
  5. move perimeter coil from old front to old back side
  6. use BumperDuino as bumper sensor
New rubber tires
pushcart tires adapter
Pictures
  1. BumperDuino
  2. pushcart tires
  3. Demo
  4. Optimized tires
  5. Bicycle tube tires for 'off-road'
  6. Ardumower rear/front driven climbing difference
Other ideas
Forum
