Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
Pi Software part
You need to send some command to the PI Terminal to install so software.
Copy and past this command in the terminal after the $
sudo apt-get update
sudo apt-get install idle3
