Version vom 7. November 2020, 12:03 Uhr von Bernard (Diskussion | Beiträge) (→‎PI Initial boot with Desktop)
Level 2 Raspberry Pi
What you need
Build the SD Card
USB Dongle for mouse.
REBOOT.
First connection over Wifi
PI SIDE
Pi is ON and you can see the desktop
PC SIDE or Tablet / Phone
You have many possiblity (SSH viewer, MobaXterm, Remote Desktop etc...) , In this case I use free real VNC Viewer to connect to the PI over your network.
