Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
Disconnect the ethernet cable and Reboot All Using Start icon and Log Out.
First connection over Wifi
PI SIDE
Pi is ON and you can see the desktop
PC SIDE or Tablet / Phone
You have many possiblity (SSH viewer, MobaXterm, Remote Desktop etc...) , In this case I use free real VNC Viewer to connect to the PI over your network.
