Version vom 6. November 2020, 14:31 Uhr von Bernard (Diskussion | Beiträge) (→‎First connection over Wifi)
Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
Reboot All Using Start icon and Log Out.
PC SIDE or Tablet / Phone
You have many possiblity (SSH viewer, MobaXterm, Remote Desktop etc...) , In this case I use free real VNC Viewer to connect to the PI over your network.
Instal the software
