Bluetooth
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
PC remote control application
We have developed a remote control application for PC (developed in Processing/Java):
- Download Windows 32 bit executable (can be run on 64 bit too) and extract it:
- Download and install Java runtime: https://java.com/de/download/
Bluetooth module configuration steps
Communication protocol
Example communication:
title [text1] [text2] [text3]
Sensor logging
