Perimeter wire
Perimeter v1 (v0.9.3)
So, here's the sender:
Functional test
Receiver
Principle:
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
- Perimeter stop test
- Perimeter tracking test
Perimeter v2 (SVN version)
While crossing the perimeter loop, something interesting happens: signal changes polarity, that means negative and positive voltages reverse each other. By using this principle, crossing the perimeter wire will be detected. The robot knows its current perimeter state all the time (inside/ouside). As with perimeter v1, we will again use a motor driver to generate the signal and an operation amplifier to amplify the received signal.
Principle:
- Amplify perimeter coil signal using OPAMP
- ADC sampling using Arduino
- Signal filterung and detection using a digital filter (Matched filter algorithmn).
- Evaluation of filter output
Simulation
Signal shape and matched filter is simulated here: Matched filter simulation
The motor driver is driven by 3.2 Khz (two pulse widths 4.8 Khz and 2.4 Khz). The circuit draws max. 20W (12V, 1.7A). We use a motor driver with integrated current limiting and thermal switch-off (e.g. MC33926).
sender circuit:
motor driver Vin o-- 12V
|---------o-- GND
|---------o-- Arduino +5V
Example of sender implementation on a dot matrix board: [1]
[2] [3]
Receiver
receiver circuit:
LM386 IN o------- capacitor 4,7nF ----------- coil 100 mH
ADC calibration
Example plots (pfodApp)
sig: coil signal mag: filter result (negative: inside, positive: outside - strengh: distance to perimeter) smag: filter output without sign, low-passed in: inside (1) oder outside (0) cnt: number of "inside-outside" transitions (counter) on: perimeter active (1) or inactive (0)
