IMU
Version vom 11. Mai 2017, 11:11 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Abstract)
                noise dps/sqrt(Hz)
L3G4200D        0.03
ITG3200         0.03
L3GD20          0.03
BMG160/BNO055   0.014
MPU9250         0.01
L3GD20H         0.011
LSM9DS0         0.00875
BMI160          0.007
MAX21003        0.007
L2G2IS/L2G3IS   0.006
MPU9150/MPU6050 0.005
ADXRS290        0.004
CRM100/200      0.003
GYPRO2300       0.00277
LSM303DLM
  • Compass sensor: HMC5883L
  • Gyro: L3G4200D
Calibration abstract
Example measurements
Calibration steps
Calibration quality test
  1. Robot dance
  2. Keep on track
  3. Driving lanes
