Motor driver
- Two motors (with integrated gearing) for driving (wheel motors) with integrated encoders (for distance and speed control)
Voltages
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- 24V (load current ~1A)
Motor decrease noise
Protector PCB
Protector board is adviced to be used between controller and motor
- Building video: Dual MC33926
Motor wiring (left motor):
Odometry wiring
Mower motor wiring
Motor wiring (mower motor):
Motor controller (PID)
