Ardumower chassis
Version vom 15. Februar 2016, 11:22 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Ardumower 1.0 Chassis specifications)
  • Total weight: approx 9 kg (including all components - motors, battery, PCB etc.)
  • Adjustable mower motor height
  • Max. slope: 14 degree
  • Mowing motor: 24V DC, 3150 rpm
  • Mowing slice: 190mm diameter, 3 blades
  • Wheels: 250mm diameter
  • Gear motors: 2 x DC 24V planetary drive, 33 rpm, with encoders (required)
  • Battery: Lithium-Ion 29.4V
  1. Chassis assembling
  2. Chassis assemling (slow)
  3. Overall impression
  4. Loundness test
  5. Gear motor test
  6. Gear motor hardness test
  7. Mowing motor hardness test
  8. Perimeter wire test (indoor)
  9. Perimeter wire test (120m outdoor)
  10. Obstacle detection via motor current
  11. Obstacles detection via ultrasonic
  12. Robot releases itself
  13. Robot releasing long-time test
  14. Plastic blades test
  15. Docking test (very initial prototype)
  16. Rain sensor test
  17. 3D simulation
What you need
  • Screw driver
  • Imbus screw driver
Case assembly
... Your help is needed to fill in photos here ...
Gear motors
Tires
Mower motor
Mowing disc
Ardumower Chassis 'mountain mod'
