Error codes
If your robot beeps periodically, it is in ERROR state. Either run the serial console or 'pfodApp->Error Counters' to find out the detailed error. The possible solutions for each error are given below.
* Check gear motor driver module and left gear motor
* Check gear motor driver module and right gear motor
* Check mower motor driver module and mower motor
ERR_IMU_TILT IMU tilt error
* Check RTC module connections, battery etc.
* Check left odometry cable
* Check right odometry cable
ERR_BATTERY Battery error
* Check battery connections
ERR_CHARGER Charger error
* Check charger connections
* Check GPS cables
ERR_GPS_DATA GPS data error
* Check GPS antenna and cable
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Console output
--- commands ---
