Version vom 10. Juni 2015, 11:11 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth not connecting?)
Error codes
If your robot beeps periodically, it is in ERROR state. Either run the serial console or 'pfodApp->Error Counters' to find out the detailed error.
 ERR_MOTOR_LEFT          Left gear motor error
                         * Check gear motor driver module and left gear motor
                         * Check gear motor driver module and right gear motor
                         * Check mower motor driver module and mower motor
                         * Check RTC module connections, battery etc.
                         * Set ans save RTC date and time
                         * Check left odometry cable
                         * Check right odometry cable
                         * Check battery connections
                         * Check charger connections
                         * Check GPS cables
                         * Check GPS antenna and cable
Disabled all pins not connected
Motors working correctly
Some sensor not triggering?
  1. Verify that BT module baudrate is configured properly (using Ardumower Console) - activate programming button on BT module for programming procedure.
  2. Verify that BT module is 'paired' on your Android phone
  3. Verify that Arduino Mega is not powered via USB (but DC/DC instead)
Console output
 START
 Ardumower rXXXX
 press...
   d for menu
- After-home-drive? (1/0)
yaw - compass course
bat - battery voltage
chg - charger voltage sensor
--- commands ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
  1. Diagnostic
