Error codes
If your robot beeps periodically, it is in ERROR state. Either run the serial console or 'pfodApp->Error Counters' to find out the detailed error.
ERR_MOTOR_LEFT Left gear motor error - Check gear motor driver module and left gear motor ERR_MOTOR_RIGHT Right gear motor error - Check gear motor driver module and right gear motor ERR_MOTOR_MOW Mower motor error - Check mower motor driver module and mower motor ERR_MOW_SENSE Mower motor over-current - Check mower motor driver module and mower motor ERR_IMU_COMM IMU communication error - Check IMU module connections ERR_IMU_TILT IMU tilt error - Check IMU module and robot orientation ERR_RTC_COMM RTC communication error - Check RTC module connections, battery etc. ERR_RTC_DATA RTC corrupt data error - Set ans save RTC date and time ERR_PERIMETER_TIMEOUT Perimeter signal timeout - Check perimeter sender, wire etc. ERR_TRACKING Perimeter tracking error - Check perimeter sender, wire etc. ERR_ODOMETRY_LEFT Left motor odometry error - Check left odometry cable ERR_ODOMETRY_RIGHT Right motor odometry error - Check right odometry cable ERR_BATTERY Battery error - Check battery connections ERR_CHARGER Charger error - Check charger connections ERR_GPS_COMM GPS communication error - Check GPS cables ERR_GPS_DATA GPS data error - Check GPS antenna and cable ERR_ADC_CALIB ADC calibration error - Start ADC calibration (either via Console or pfodApp->ADC calibration) ERR_IMU_CALIB IMU calibration error - Start IMU calibration (either via Console or pfodApp->Settings->IMU) ERR_EEPROM_DATA EEPROM data error - Save user settings (either via Console or pfodApp->Settings-Save)
Disabled all pins not connected
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Console output
--- commands ---
