Charging
Version vom 5. Juni 2015, 08:57 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Standby-off / Under-voltage protection)
Basic principle
Charger
Total power balance
Battery
Idea:
  1. User presses existing START/POWER button, that switches on the MOSFET for the time of pressing
  2. Arduino starts and immediately also switches on MOSFET (via Arduino pinBatterySwitch)
  3. If undervoltage detected, Arduino switches off MOSFET (via Arduino pinBatterySwitch)
  4. Emergy button is still used for completely switching ON/OFF power
  • POWER/START button: switches-on operation voltage (1st one second press), starts robot in automatic mode (2nd one second press)
BOM:
1x IRF9540N  P-MOSFET   T1   (or IRF5210)
1x BC337 NPN   T2
1x Zener Diode 15V ZD15  Z1
2x Diode 1N4148 D2, D3
2x Diode 1N5819 50V D1, D4
1x 22 uF C1
1x 1k R4
2x 10k (R3, R8)
1x 30k R6
2x 100k  (R2, R7)
Robot charging
robot charging circuit:
                             ---- voltage sensing
Charging station
charging station circuit:
                    GND         (-)----- Charging station charger pin(-)
Charging station ideas
  2. Drive in and out
  3. Tracking and docking
